Charge 5 is taking too long to sync
ANSWERED
SYNC takes too long time
1 BEST ANSWER
Accepted Solutions
Hi there, @Abhay118. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
As a first approach, please follow @Gr4ndp4's tips and recommendations.
If the above doesn't work, I'd recommend trying the following steps:
  • Unpair your Charge 5 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Charge 5.
  • If there is no connection, restart your Charge 5.
  • Set up notifications again.
  • Once your Charge 5 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
2 REPLIES 2
Hi, @Abhay118 welcome to the community, syncing is not instantaneous and in order to retrieve some data - like sleep score - a second sync is necessary (slide your finger down the Today screen & release) Your phone app will always sync when you open the app.
You may find these articles of interest How do Fitbit devices sync their data? & Why won't my Fitbit device sync?
I hope this helps.
Cheers
Gr4ndp4 | UK
