06-20-2023
00:41
04:58
06-20-2023
00:41
04:58
My charge 5 has completely died, no lights, black screen, no vibration on attaching to charger.
It's all clean.
Update: And yes, I've tried the reset thing, no response at all.
Best AnswerHi, @ChrisGriffiths, welcome, talk to "Customer Support" using the chat facility or phone for a prompt response. Before making the call make notes of the steps you have taken & the results so you can brief the agent clearly and quickly. You do not mention how long you have had your Charge 5, you may still have the benefit of Fitbit's warranty depending on when you bought it and who you bought it from (the agent will need this info if you are covered)
I hope this helps.
Cheers
Gr4ndp4 | UK
Hi there, @ChrisGriffiths. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Charge 5 before posting here. Thanks for the steps you've provided and your advice @Gr4ndp4!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Best AnswerHi, @ChrisGriffiths I'm pleased you've contacted Customer Support, I note your device is less than a year old, so subject to where you bought the device you will almost certainly be covered by the warranty.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @ChrisGriffiths, talk to Customer Support.
Cheers
Gr4ndp4 | UK
