07-31-2023
14:34
05:44
07-31-2023
14:34
05:44
I’ve only had my Charge 5 for a year. It is now unresponsive. The sensor on the underside doesn’t blink, the screen doesn’t turn on, and there’s no vibration when I plug it up to charge. I’ve tried the steps to reset it multiple times and nothing has worked.
Best Answer08-01-2023 06:16
08-01-2023 06:16
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
As per the description of your post, it seems like your Charge 5 is having battery issues. If you've tried charging your Charge 5 for more than 2 hours but to no avail, please see Why ins't my FItbit device's battery charging?
If the above doesn't work, connect your Charge 5 to the charger and try the following (while it's connected to the charging cable and even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer08-01-2023 06:23
08-01-2023 06:23
