03-27-2024
10:01
11:04
03-27-2024
10:01
11:04
Hi
My charge 5 is completely unresponsive and will not charge. I have followed recommendations on all other posts but nothing happening. Will not sync, will not charge, completely black screen and no light.
Best Answer03-27-2024 11:07
03-27-2024 11:07
Hi there, @Jayne54. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still unresponsive. I will do my best to help you with this!
As a first approach, please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Charge 5. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If the above doesn't work, please see Why isn't my Fitbit device's battery charging?
Best Answer03-27-2024 11:19
03-27-2024 11:19
Best Answer03-27-2024 11:34
03-27-2024 11:34
Hello @Jayne54
Since you've tried the recommended troubleshooting steps without success and your device is less than a year old, you should contact Fitbit support (<-- click link) to find out what are your options under warranty.
