02-05-2025
14:05
05:20
02-05-2025
14:05
05:20
My watch is continually cutting out but when I put it on the charger it shows there is around 25% battery. What is causing this?
02-07-2025 05:23
02-07-2025 05:23
Hi there, @Heldo1967. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is not working properly. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Charge 5 on the wall socket, try using another CE certified USB adapter for low energy devices.
If you haven't done so yet, I'd recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
