03-12-2022
15:27
16:48
LizzyFitbit
03-12-2022
15:27
16:48
LizzyFitbit
The charger cable is no longer maintaining a secure hold on the fitbit and it causes the charge thing to rapidly come and go when I try to charge the fitbit, till it shows an error saying that the battery is not charging. I've used a tooth brush to clean both sides and it didn't help, I tried various methods of cleaning the connection points and nothing improved the connection. I have to push a little harder now to make it connect and try to line it up perfectly which is hard because of the stupid magnet.
I miss the Fitbit Charge 3 honestly. It had a secure connector, with a physical button on the side for going back a screen instead of this "swipe only" system. In any case the connector in this case is the problem. There's no way for it to totally secure its self to the watch. It doesn't latch around like the old version did. At first I liked it, but now I've only had this for a few months and its barely working.
03-13-2022
16:51
09:24
03-13-2022
16:51
09:24
Hi there, @VasVadum. @Rich_Laue and @GaryOwhere Thanks for stopping by to help our member.
@VasVadum Thanks for the detailed information, and your efforts while working on this matter. I'm sorry you've had this experience with your Charge 5 and because the issue seems to be with the charging cable, I'd recommend contacting our Support team. They've specialized tools that will allow them to evaluate your options and bring you back on track. They're available via chat and phone, just click here to get connected with them.
I'll look into that later. I'm still trying to determine the exact issue. I really don't want to send in for a replacement every 3 months if I don't have to. I just wish Fitbit hadn't changed the design so much and made certain features more useless. I actually miss my Charge 3.
03-17-2022
18:57
09:24
03-17-2022
18:57
09:24
Thanks for taking the time to share your feedback about the Charge 5. Every feedback shared in the Community Forums never goes unnoticed as it helps us to evaluate our procedures, as well as improve our services and the overall Fitbit experience. I understand your concern and please know your comments won't go unnoticed.
In case you need further assistance, you can always use the link shared in my previous post to get in touch with our Support team.
