04-09-2022
11:03
09:56
04-09-2022
11:03
09:56
Hi, welcome to the Fitbit Community forums, @Tommo56.
I appreciate all this information that you've shared about the inconvenience that you've been having with your Charge 5.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
Hope this helps, I'll be around.
08:35
05:46
DavideFitbit
03-02-2023
08:35
05:46
DavideFitbit
No problem for 14 months until I installed latest update a few days ago. Now total discharge in a few hours. What is going on at Fitbit? They need to address this urgently.
What we all need is an explanation of why this discharge issue has suddenly become a problem with many owners in the recent past. No problem for 14 months then rapid discharge occurring as an issue. Not good enough
03-16-2023
05:46
09:56
03-16-2023
05:46
09:56
Hi everyone, thank you for confirming that you're still experiencing this inconvenience with your Charge 5 and that you already tried a few troubleshooting steps.
In this case, if you already tried all the steps mentioned here earlier to improve the battery life, I recommend that you continue the communication with the Customer Support team for further assistance. They will let you know about the next steps.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
See you around.
