10-01-2021 13:21
10-01-2021 13:21
My new Charge 5 is not mapping my walks. I have an Android and have it paired to bluetooth, have given Fitbit location access "all the time" in settings for the app, gps is set to on on the Fitbit and I wait till the Fitbit shoes it's connected to GPS. The app registers my steps, distance, etc, same as I would get without using the exercise function, but no map or the stats that come with maps. My Charge 4 produced maps with no problem.
10-02-2021 02:53
10-02-2021 02:53
I contacted the support in a similar case. No map and tha distans was of by 10% and som runs 40%
The answer I got was basically: "Thanks for letting us know about this issue. We’re aware of it, but may not be able to provide a fix in the immediate future"
Best Answer10-02-2021 13:38
10-02-2021 13:38
I had the same problem and changed setting to built in from dynamic. I used dynamic on my charge 4 and never had a problem with the map. I get the maps since changing but I'm now finding distances are off. In one case charge 5 calculated 2/3 of a mile more than the distance with my charge 4. I validated the distance using my vehicle and the charge 5 is incorrect.
Best Answer10-03-2021 03:01
10-03-2021 03:01
Even on dynamic or phone connection the GPS data it utterly useless.
This product is not built to be a fitness tracker unfortunately
10-03-2021 03:25
10-03-2021 03:25
Thank you, that's really disappointing. It seems like a pretty basic function to have messed up when it worked on the previous model.
10-03-2021 03:31
10-03-2021 03:31
I get no mapping on any of the gps options, not even wrong ones. Seems like this product was not ready for prime time. From what customer service told you, it sounds like they are claiming it's a software issue, but I wonder if it's a flaw they can't fix but don't want to be deluged with returns,
10-03-2021 03:37
10-03-2021 03:37
My thinking is that it is a design flaw. The GPS unit is to low in the device.
10-03-2021 04:49
10-03-2021 04:49
Thank you for your analysis. Bummer. Last time I'll preorder anything rather than wait to hear what happens when people start using it.
10-04-2021 09:59
10-04-2021 09:59
I've found that when it was on dynamic it didn't work, but when I switched to phone GPS it worked fine and the mapping was fairly accurate. Having said that, I don't normally use my Fitbit to track runs as I prefer to use my Garmin so a somewhat less than perfect GPS function isn't a deal-breaker for me.
Best Answer10-04-2021 11:50
10-04-2021 11:50
Thanks, that's the one gps option I haven't tried. I'll give it a try, but I note that Manneman did not find it accurate.
