10-04-2021 06:19
10-04-2021 06:19
Hi, I wanted to know if there is a possibility to count steps while pushing a stroller.
I though an integrated GPS would be the solution for this, but it's not really working.
Any idea?
Thanks!
Best Answer10-04-2021 06:43
10-04-2021 06:43
If you arm isn't moving you won't get steps. I put my Fitbit in my pocket whenever I'm pushing a shopping cart or wheelchair. I've had the Fitbit One, Alta, Alta HR, Charge 2, Charge 3 and Charge 4. The ONLY one that counted steps properly was the Fitbit One, which I clipped on to my pants pocket. Stair counts are a joke as that count is more about atmosphere (wind) than stairsteps.
10-04-2021 09:26
10-04-2021 09:26
Oh! I had Alta HR and I thought this would be fixed having the GPS. What’s the GPS for then? Does it counts km well if I’m pushing the stroller? Didn’t check this.
Thanks!
Best Answer10-04-2021 10:34
10-04-2021 10:34
GPS is for mapping routes when walking or running. When I've used it to track cycling, I get relatively few steps. For instance, a 28km bike-ride yielded 5000 steps so I'm not sure it'll help compensate for step tracking lost while pushing a buggy.
