04-01-2023
14:04
09:34
DavideFitbit
04-01-2023
14:04
09:34
DavideFitbit
04-02-2023
09:32
08:55
04-02-2023
09:32
08:55
Hi, it's good to see you visiting the Fitbit Community for the first time, @Tholi.
Thank you for the information provided regarding the inconvenience with your Charge 5 notifications and for the screenshot provided.
Before taking any other options into consideration, please make sure that you've tried the steps listed in this article, as they have been helpful for other users experiencing something similar, and you can also try to disabling the notifications completely and setting them up again.
In addition, please check that the Do Not Disturb Mode and the Sleep Mode options are not activated, as they prevent the watch from vibrating and receiving notifications.
If you're still having the same problem, other users have also found the steps below helpful:
You can find other useful tips for using the Fitbit app on Android devices here.
