08-26-2022 16:52
08-26-2022 16:52
Charged it overnight. Put on this am. Went for my usual 5km walk got home and noticed no steps, no heart rate just a clock face. What is going on? Less than a month old! Plus battery has drained to 47% in less than half a day. Not happy as upgraded to the 5 as my 4 kept not responding. Please help.
Best Answer09-17-2022 12:26
09-17-2022 12:26
Welcome to the Fitbit Community forums, @LindaGosling.
Thank you for sharing this information about the issue you're experiencing with your Charge 5.
The restart procedure is usually helpful to resolve these type of issues. If you haven't done so already, I recommend that you try restarting the device using the three pulse restart method, instead of the restart option available on the device's settings:
In addition to the restart, you can also try setting up your Charge 5 as a new device in your account if you're still having the same problem. Regarding the battery draining too fast, the restart could be of help, but you can also find some other recommendations to improve battery life in general here.
Hope this helps, I'll be around.
