05-12-2023 13:05
05-12-2023 13:05
The display of my Charge 5 does no longer react when I tip with the finger. I have tried to restart my watch and got to see the logo and the full batterie, but right afterwards the screen turns black and does not react anymore. I tried the proceedure of restarting several times but got always same outcome. Is there another option to restart Charge 5 then using the cable and pressing the buton 3 times? Thanks for your support…
Best Answer05-12-2023 14:52 - edited 05-13-2023 06:18
Check if you are in Sleep Mode, intentionally preventing display from coming on with screen tap.
My mistake. Sleep Mode would not explain this; screen tap would still turn on display, just in dim mode.
05-12-2023 23:56
05-12-2023 23:56
Let‘s assume it is in a sleep mode. How can I turn it off without being able use the screen? It is black and does not react to tapping at all.
Best Answer05-13-2023 06:16
05-13-2023 06:16
My mistake. Sleep Mode would not explain it. I guess I was thinking of another model with a side button to push. Even in Sleep Mode, tapping should wake the display, though in in less bright mode.
Sorry, but I'm afraid I'm no help on this.
