10-27-2022
00:47
06:52
DavideFitbit
10-27-2022
00:47
06:52
DavideFitbit
Why does it constantly register start of sleep about 1 hour after it actually happened? But on the other hand it also registers end of sleep much later than it happened, if I'm just laying in bed listening to the radio in the morning. Puzzled. (FW updated, on dominant right arm, set to dominant arm, measures everything else correctly but not start and end of sleep.)
06:51
10:05
11-01-2022
06:51
10:05
Hi, thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5, @Delta99.
Keep in mind that when your body is completely at rest and you haven’t moved for about an hour, your device should record that you’re asleep. Before considering other options, please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Regarding the device not recognizing that you're awake, please follow the steps listed here below as well:
Hope this helps, I'll be around.
