06-10-2023
03:29
05:31
DavideFitbit
06-10-2023
03:29
05:31
DavideFitbit
My Charge 5 for some reason has stopped tracking my sleep ever since saturday, and it fails to sync to my phone no matter how many times i try to refresh it (pulling the screen down on home menu). The watch still should be able to track sleep regardless of it being connected to a phone though right? I’ve tried reinstalling the app, turning off/on the auto sleep mode, nothing seems to work. Anyone have any suggestions? Please let me know if you need any more info on it.
06-11-2023 05:31 - edited 06-11-2023 05:32
Hi, welcome to the Fitbit Community forums, @lasale @Cazzzzy @Charge_5.
Thank you for sharing this information about the inconvenience you've been experiencing with the new Charge 5.
Before considering other options, please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
If you haven't done so already, please try to complete a restart procedure following the steps listed here below:
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
@Cazzzzy If your device is not tracking heart rate, the restart should be of help, but you can also find other recommendations here on how to properly place the device on your wrist.
@lasale If you're still having issues to sync your data, please follow the steps listed here.
06-10-2023 05:14
06-10-2023 05:14
Same issue. Have noticed the heart monitor has stopped working and when I take it off - the lights are no longer on. I reckon it’s all connected. Will try cleaning, full charge & reset and then no doubt will need to contact FitBit. It better not be faulty as I’ve only just had it over a year…
06-11-2023 05:31
06-11-2023 05:31
I’m having the same problem and I just contacted customer support through the chat service which was not helpful.
06-11-2023 07:09
06-11-2023 07:09
I too am having the exact same issues as @Cazzzy and @Charge_5 not tracking sleep, not tracking heart rate and no green light.
Best Answer06-11-2023 09:47
06-11-2023 09:47
My Charge 5 has the same issues, not syncing, not recording sleep, not correctly tracking steps, for the past few days.
Best Answer07-12-2023 06:05
07-12-2023 06:05
