02-08-2023
05:52
14:18
LizzyFitbit
02-08-2023
05:52
14:18
LizzyFitbit
Notifications are getting through to my charge 5 but the band does not vibrate. Vibrate is working on the band - I checked with an alarm. Alarm is set to strong. I see other users have had vibrate problems but no solution is shown here. How do I fix this.
02-12-2023
14:21
05:56
02-12-2023
14:21
05:56
Welcome to the Community, @paultheboat.
I've moved your post to the Charge 5 board so we can keep the forums organized. Thanks for the details and your efforts in testing the alarms. I understand your concern and just to confirm, have you tried restarting your Charge 5? If not, please give a try to the following steps and monitor its behavior afterward:?
Best Answer02-13-2023 09:30
02-13-2023 09:30
03-12-2023
16:21
05:56
03-12-2023
16:21
05:56
Hi there, @paultheboat.
You're welcome, thanks to you for getting back with more details as well as trying the restart process one more time. While this is odd, could you check if the DND or Sleep Mode are turned off? To check this, just swipe down from the clock screen, and tap a setting to adjust it. When you turn off a setting, the icon appears dim with a line through it.
If the issue persists after doing that, let's try setting up your notifications one more time:
