07-07-2023
14:05
10:56
ManuFitbit
07-07-2023
14:05
10:56
ManuFitbit
My charge used to last 5 days plus, now only lasts 6 hrs! Goes to fitbit icon...
Moderator edit: clarified subject.
Best Answer07-07-2023 14:32
07-07-2023 14:32
Welcome to the Fitbit community, @Riggiec!
Sad to hear you're having issues with your Charge 5. As a first attempt to get things fixed I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'll keep my fingers crossed.
Best Answer07-07-2023 15:05
07-07-2023 15:05
