Charge 5 randomly turns off
Charge 5 randomly turns off. Tried the suggested fixes. Restarting didn't solve it. Changed clock faces and it turned off half way through. Seems to be bluetooth disconnects as well. Thinking of switching to Garmin. -intitle:"android" -intitle:"google play" -intitle:"google payments"
1 REPLY 1
Hi there, @CdnoldguyThanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still crashing. I understand your concern, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Charge 5. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Charge 5 and then, proceed with the steps below in the order listed:
  1. Swipe down from the clock screen to find the Settings app.
  2. On your Fitbit device, open the Settings app > Device Info > Clear User Data
You can follow the steps to set up the device after that How do I set up my Fit-bit device?
