Charge 5 screen fell off
ANSWERED
I noticed my fitbit charge 5 screen sounded weird. I when I took a closer look, the screen had opened up. Now am keeping it closed with scotch tape. This is my 4th fitbit and all these issues, I don't think I will purchase another one. I'm so disappointed because I like fitbit.
1 BEST ANSWER
Accepted Solutions
Hi @Gac1362  if the Charge 5 is still working, there is a way for you to keep using it, without the tape. Check out "protective band cover for Fitbit Charge 5" at Amazon. It takes the pebble and places it in a band where the front and back is completely enclosed, so you can still use it. Might be a solution for you instead of the tape.
Stepping in the U.S.A. since September 2013. Android 14
4 REPLIES 4
Thank you. I will check it out.
Hi Odyssey,
I took your advice and purchased the protected cover  for my fitbit charge 5. It works really well.
Thank!
Gac1362
Wonderful news @Gac1362 and I'm sure your posts will help others who might find themselves with the same situation. Keep on stepping!
