07-30-2025
23:30
06:26
07-30-2025
23:30
06:26
I only have this screen. I can't scroll to anything. The charger buzzes when it connects so the charger works. But the fitbit won't restart if I try and use the button on the charger. It also won't sync on my phone so I can't try and fix it with the app. My only idea at this point is to let the battery drain and try the above steps again.
Hi there, @GoblinGhost. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention, for the troubleshooting steps you've tried, and for the image attached. I'm sorry to hear that the screen of your Charge 5 is not working properly. I understand your concern, we're here to help you!
To better assist you, I suggest reaching out to our Support Team who will be able to take a closer look into this issue and provide further help. This form is only meant for you to use. Click here to get access to it.
Press and hold firm for 10 sec.
Also try repeated side swipe left to right (top to bottom or bottom to top won't work.
