12-04-2023
07:46
10:19
12-04-2023
07:46
10:19
How do you make the screen brighter? It keeps going back to dim.
Best Answer12-04-2023 10:24
12-04-2023 10:24
Hi there, @Barb5512. Welcome to the Fitbit Community Forums. It's sad to hear that your Charge 5 screen keeps going back to dim. I'll do my best to help you with this.
As a first approach, I'd recommend checking whether your Charge 5 is in sleep mode. When sleep mode is on:
If the above doesn't describe your issue, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
12-04-2023 10:24
Hope that helps.
