Hi
My Charge 5 wasn't recording my sleep score reliably.
I was using the "Begin Now" sleep feature on the app to record the fact I was going to sleep and found there was a good chance it didn't show a score in the morning.
HOWEVER, I then discovered that it is possible to turn the sleep mode on from the Fitbit device itself - it's a couple of swipes down from the main menu. Since I started using this feature on the device rather than the "Begin Now" feature on the app the Sleep score has recorded 100% of the time.
Hope this helps.
C
Hello & welcome @ColinM316
Thank you for sharing your troubleshooting tip so others can benefit from your experience. I'm glad to know that you discovered a way that helps you get your Sleep score.
