07-10-2022 07:45
07-10-2022 07:45
Has anyone had their charge 5 start beeping every 5 seconds? I have a ticket in with support, but I wanted to see if anyone has had this happen and if they had to get a replacement.
Best Answer07-10-2022 07:55 - edited 07-10-2022 07:59
Hi, @PSmanning, welcome to the community. Check that you have not inadvertently set a countdown timer. From the clock screen swipe right to "Timers," >swipe up check all are off. The Charge 5 does not beep but rather vibrates with a very quiet buzz. If you are getting "BEEPS" can you confirm you are using a Charge 5 please?
I hope this helps.
Cheers
Gr4ndp4 | UK
