11-06-2024
01:56
05:00
11-06-2024
01:56
05:00
My Charge 5 has stopped working. It is just over two years old. The screen is blank and it won't charge. The app states it last synced on the 1/11 but can not connect to the device. I have tried different USB ports and have pressed the button 3 times and unplugged and re plugged but no joy. Am I missing anything or is it time to buy a Charge 6 / switch to an alternative?
Hi there, @AHW4S. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still not charging. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Charge 5 on the wall socket, try using another CE certified USB adapter for low energy devices.
To better assist you, please confirm that you've tried all tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Best AnswerAppreciate your response. I have tried a number of sockets and USB adaptors without success. I have also cleaned the contacts and checked the connection but sadly still no joy. I presume it is out of warranty so may have to replace / look at alternatives.
@AHW4S Since all the steps you tried didn't work, you have a Charge 5 and report it's not charging, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
Best AnswerThanks - I completed the form a few days ago and have heard no more. Hopefully all the information has been provided but if not let me know.
