04-08-2024
07:14
09:55
04-08-2024
07:14
09:55
Hi
My Charge 5 watch is unable to track anything. Steps are not logged, heart rate is no longer logged and/or tracked. I am able to sync between the watch and app and nothing is logged. I have done the following:
- Removed the app from my phone, reinstalled and re-added watch.
- Connected watch to charger and pressed charger button 3 times within 8 seconds.
- Rebooted the watch from the 'Settings' tab on the watch.
Any help much appreciated.
Thanks,
Jonny
Best AnswerHello @jonnymc4
That's so disappointing.
Do you see a green light on the back of your Charge 5? You can check by placing your finger across the back. You should see a green light when you lift your finger. That's the heart rate sensor.
If you're not seeing the green light, the first thing to check is that the Heart Rate setting didn't get turned off somehow:
If Heart Rate is turned on and you still don't see the green light, try turning the setting off, then back on. You might also want to try restarting your Charge 5 after turning the Heart Rate off, then back on. I've found that doing a restart often helps get my Fitbit "unstuck".
According to posts I've read, some users reported that doing a factory reset worked to re-enable the sensor. This might work to restore your Charge 5:
Hopefully, you should see the green light on the back of the Charge 5 after the reset and it resumes tracking your steps. If you see the light, then set up the Charge 5 in the Fitbit app as a new device. Although it's usually not necessary, I recommend deleting the previous Charge 5 from the app first.
If you didn't see the green light return and you're not getting any steps after the factory reset, then it's likely your Charge 5 is defective. You should contact Fitbit support (<-- click link) to find out what are your options under warranty
