04-09-2024
04:18
06:56
04-09-2024
04:18
06:56
The screen turned totally black only after few mins (two laps only). I did turn on the swim mode and searched online beforehand. The 50m water resistance seems to be a FAKE marketing, as I just saw numerous people reported the same issue here: https://community.fitbit.com/t5/Charge-5/Water-damage-first-time-Charge-5/td-p/5256358. The thread was closed to replies, otherwise I could have seen a LOT MORE...
I have been a Fitbit user and switched to charge 5 less than 2 years ago. I have to say this model is way disappointing, compared to charge 3 which I used for 4-5 years before the battery died out. Software, quality of build, comfortable level, and now the fake marketing.. I know mine is out of warranty so I won't waste time further.
End of vent.
Hi, @kzf24, welcome to the community, I used my Charge 5 for many months swimming daily. Provided your device is damage-free it's good for swimming (as are all the Fitbit devices & Pixel Watch)
You mention your Charge 5 is about 2 years old, depending on the number of charge/discharge cycles it's seen it may be at the end of its useful life. It is worth checking that your device is charged Why isn't my Fitbit device's battery charging? - Fitbit Help Center provides assistance & guidance. Try restarting your Charge 5 as demonstrated in This video @ 1:29
If your device is less than two years old you may still have the benefit of Fitbit's return and warranty policy depending on when, where & from whom you bought it.
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
Cheers
Gr4ndp4 | UK
Hi there, @kzf24. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 has stopped working after getting wet. We‘re taking your comments and sentiments in regards to our products and services into consideration.
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, may I know if your Charge 5 vibrated during the restart process? If it didn't, I'd recommend trying the steps below:
If nothing seems to work, please follow @Gr4ndp4's advice and chat with us online or give us a call. Click here to get connected.
Thank you @Gr4ndp4 and @MarreFitbit for reply. A few further clarifications:
Anyway thanks for replying and very detailed instructions - they are very helpful. Have to say Fitbit still hits some of my sweet spots which means it's a good product. I will reach out to support first.
