06-30-2024 12:44
06-30-2024 12:44
Hi!
Charge 5 stopped working after getting wet in a children pool.
It was fully charged the same morning,I tried to push the cable botton x3, to change charger, but nothing is bringing my fitbit back to life.
What should I do?.
Thank you,
Best Answer07-02-2024 04:00
07-02-2024 04:00
Hi there, @elebramby. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still unresponsive. I understand your concern, I will do my best to help you with this!
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, may I know if your Charge 5 vibrated during the restart process? If it didn't, I'd recommend trying the steps below:
Best Answer07-02-2024 07:22
07-02-2024 07:22
I just had same issue after barely getting it wet in a shallow pool. My watch is just over 1 year old. I tried the reset process and it is still not displaying anything. My Charge 5 did vibrate during the restart process. Are there any steps to try to get my Fitbit to display once again?
07-05-2024 18:59
07-05-2024 18:59
I am having the same issue which started this morning. I did the reset too and the device vibrates like yours. Will follow to see if there are any additional responses to your post.
07-11-2024 10:33
07-11-2024 10:33
My older Charge 5 died after I had a long walk in the rain. Luckily, it was under warranty and I received a replacement.
Nowadays, the watch is out of warranty and I cover the watch when I walk in the rain again.
And this will probably be my last Fitbit product because it does not sync natively with Apple Health. And other sync apps all cost a lot for the subscription.
