05-31-2024
12:13
13:18
05-31-2024
12:13
13:18
Died a sudden death… won’t charge… I see a number of users have the same issue???
any ideas of id it consigned to the bin
05-31-2024 13:31
05-31-2024 13:31
Hi there, @Keredewor. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 has stopped working. I understand your concern, I will do my best to help you!
To better assist you, would you mind sharing with me more details of the issue? Is your Charge 5 not charging? not turning on?
If you stopped wearing your Fitbit device, it might have run out of battery. Being that the case, please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Charge 5. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If the above doesn't work, please see Why isn't my Fitbit device's battery charging?
Best Answer06-01-2024 23:43
06-01-2024 23:43
Dead as a dodo… none of the above worked
