01-09-2026
19:17
03:40
01-09-2026
19:17
03:40
So I see the Charge 5s are still just dying for no reason. Has Fitbit given any reason or are they still acting like nothing is wrong .
01-10-2026 03:45
01-10-2026 03:45
Hi there, @jwilliamsr90. Thanks for stopping by in the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Charge 5 stopped working. I understand your concern, I will do my best to help you with this!
To better assist you, I'd like to know what the issue is. Is your Charge 5 not syncing, not charging? Have you tried charging it? Sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging. For more information, see Why isn't my Fitbit device's battery charging?
It can take more than 10-15 mins to go from 99% to 100%. Personally, I never tend to charge my electronic devices to 100%, I've learned that the best way I can preserve the battery life is when I charge them to 80%. I charge them when the battery is at 20% then wait until it's at 80%.
If the above doesn't describe your issue, please share with me more details of the issue to address it properly. Also, let me know if by any chance you've already tried some troubleshooting steps to rectify the issue.
Looking forward to hearing from you.
Best Answer01-16-2026 14:09
01-16-2026 14:09
I have the same issue. I've tried all the troubleshooting steps; reboots etc.... Battery life is a lot shorter than it used to be and readings are inaccurate but I feel confident that's not the issue since it locks up even on a full charge. Lock up usually occurs when recording a workout. I wonder if GPS has something to do with it. I'm running GPS/Phone but I'd turn it off completely if I only could find a setting to do that. I'm with Google now, I suppose most all users are. I'm suspicious that that's when my lock ups started but can't be certain. I'm also beta for the new app with AI, which is interesting but of secondary importance if the device keeps locking up.
I'm all ears if anyone has any new troubleshooting insights or advice.
Best Answer01-18-2026 12:52
01-19-2026
13:50
15:41
ManuFitbit
01-19-2026
13:50
15:41
ManuFitbit
Thanks! I see on my Charge 5 on my wrist that GPS shows up under "Outdoor Workout". That's the only exercise for which it shows up based on my settings. I turned it off. Time will tell if that makes a difference. I can't find where to check out the specific workout settings on the app.
The overall settings only allow "Dynamic", "Built-In", or "Phone" options. There is no overall "Off" option but it seems to me there should be. I almost never need GPS. Given the available options, I chose "Phone" because I figured it would be the least demanding on my system.
At the start of my xc ski session today, I selected the workout on my Charge 5, clicked to start recording, and it went dark. Locked up. Couldn't record. On a nearly fully charged battery. This is not unusual.
01-21-2026 14:02
01-21-2026 14:02
My Fitbit 5 disconnects multiple times daily since Google took over. None of their fixes work.
