Charge 5 stuck on Fitbit logo
ANSWERED
The screen froze on the fitbit logo and won’t respond and doesn’t reset when i hit the button on the charger. What do I do?
1 BEST ANSWER
Accepted Solutions
Hi there, @kn13. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
  • Unpair your Charge 5 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Charge 5 again.
  • If there is no connection, restart your Charge 5.
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
@Talahthas Thanks for your help.
2 REPLIES 2
@kn13 Welcome to the Fitbit community!
Sad to hear that your Charge 5 isn't working properly. As restarting your device isn't done by hitting the button on the USB plug of the charging cable only once, please follow these instructions to give that a try:
1.) Connect your Charge 5 to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB plug of the charger 3 times within 8 seconds, holding each press for about 1 second(!).
3.) Wait 10 seconds or until the Fitbit logo appears.
If this doesn't work for you, please contact Fitbit support to get further assistance as your Charge 5 might have technical issues:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
