07-16-2023
14:22
05:13
07-16-2023
14:22
05:13
I can’t get my fit bit to run on it stuck on the Fitbit symbol and is frozen what do I do?
Hi there, @Lcbattle @chadkauffman. Welcome to the Fitbit Community Forums. Thanks for the details provided in your posts about the issue with your Charge 5 devices and trying to troubleshoot them before reaching out (and the image attached).
In addition to the steps you've done, please try the following:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
