08-23-2023
04:29
05:00
08-23-2023
04:29
05:00
My Fitbit keeps crashing and all I get is the Fitbit logo brick screen (the teal one). It will remain like this for several hours. Even after I connect to the charger overnight. I know it’s connected to the charger, b/c I can feel the “buzz” upon connection but still nothing.
I’ve tried the reset using the button on the power cord, and that worked the first 2-3 times this happened but now it’s not resetting.
This issue started about 2 weeks ago. The only other thing that’s changed recently is that it installed the new update. Other than that, I haven’t done anything different. Prior to this, I’d never had any issues with my Fitbit; it’s been down/broken more than it’s been functional in the last 2 weeks.
Anyone else having similar problems?
Best Answer08-24-2023 05:27
08-24-2023 05:27
Hi there, @Anastasia_N. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
To better assist you, please make sure you've restarted your Charge 5 as described here.
If the restart doesn't work and your Charge 5 doesn't vibrate during the restart process, please follow the steps below:
If the steps above don't work and you keep getting the Fitbit logo, please try the following while your Charge 5 is connected to the charging cable:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
08-24-2023 05:27
