03-19-2023
09:30
10:12
03-19-2023
09:30
10:12
Several issues with my Charge 5 over the past two weeks, quick battery drain, non-responsive, and now it is stuck on flashing logo. I tried all of the actions listed in the forum related to a hard reset with no success. It’s stuck on flashing Logo.
Hi there, @Pkmart. Welcome to the forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
Best AnswerHi
I followed these steps prior to contacting support, and again just now. No change.
I woke up, no response on my screen, put it on the charger, and since the logo has been flashing.
