06-08-2023
20:12
20:49
EstuardoFitbit
06-08-2023
20:12
20:49
EstuardoFitbit
Fitbit logo is stuck on the time screen, pls advise how to resolve it
Hi there, @ericwu6122. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. @Julia_G Thank you so much for your help!
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best AnswerHi, @ericwu6122 please try giving your Charge 5 a restart. As the screen is not showing correctly, you will need to use the button press method. The full instructions for a restart can be found in this help article . It is worth trying the restart several times, as a single restart does not always work.
If a restart does not correct the issue you could also try changing the clock face. You do this in the app and the instructions are here .
Good luck! Let us know how it goes. Welcome to the forums.
Best AnswerHi, @ericwu6122 , did you previously perform a factory reset on your Charge 5?
@ericwu6122 I'm glad to hear you're back on track!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
