09-14-2023
10:45
11:41
09-14-2023
10:45
11:41
Problem started Sept 10. Got the X in a circle and followed instructions to restart. Restart worked for about an hour. Then received a notice to update firmware. Upon confirming update, charge 5 stopped working. I deleted the devise and followed every restart procedure and only get the blinking logo. Bluetooth will not recognize Charge 5.
Seems many people have this same issue in the same timeframe.
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5 and taking the time to troubleshoot the issue before reaching out
As per the description of your post, it seems like your Charge 5 is having battery issues. If you've tried charging your Charge 5 for more than 2 hours but to no avail, please see Why ins't my FItbit device's battery charging?
If the above doesn't work, connect your Charge 5 to the charger and try the following (while it's connected to the charging cable and even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best AnswerHi, followed each step in order and still not working. The logo blinks and it vibrates approximately every 10 seconds. Any other suggestions?
