09-03-2023
01:54
05:23
09-03-2023
01:54
05:23
Hi everyone, my smatrwach died. After night the watch is turned off. While trying to charge on the screen is red "x" logo. Before night everything was fine.
Please give me any advice.
Best regards
Best Answer09-03-2023 05:25
09-03-2023 05:25
Hi there, @Eligiusz. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Fitbit device.
Please try the following steps while your Fitbit device is connected to the charging cable:
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If the above doesn't work and you don't feel any vibration while performing a restart, please try the steps provided here Why isn't my Fitbit device's battery charging?
Once you make sure that your Fitbit device is charging, try the steps above one more time.
