02-28-2023
05:20
06:01
02-28-2023
05:20
06:01
Have tried doing the re-set and holding the charger button down 3 times in 8 8 seconds but nothing happens. Those dreaded 5 dots won’t go away.
Does anybody have any other advice?
TIA
Best Answer02-28-2023 06:02 - edited 07-24-2023 06:16
Hi there, @claireandmatt. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
