09-30-2022
12:53
06:46
DavideFitbit
09-30-2022
12:53
06:46
DavideFitbit
Charge 5 stuck with logo on screen. Reboots have been unsuccessful
06:45
06:53
10-05-2022
06:45
06:53
Welcome to the Community forums, @shahzam04.
Thank you for sharing that you've having this inconvenience with your Charge 5 device and that you already tried the restart a few times.
Before considering other options, please try these additional steps that have been useful for other users:
Best Answer10-05-2022 16:32
10-05-2022 16:32
I am having the same problem a few days back and now my Fitbit is alive back.
What I did ?
I fully drain the battery of the watch by leaving it untouched.
When I charge it again..the watch is back to normal again.
Hope this can be applied to you too... Good Luck.
11:40
03:34
10-21-2022
11:40
03:34
Welcome to the Community forums, @MXC29.
Thanks for taking the time to share your feedback and experience with this. I'm sure this will be useful for other users as well.
See you around.
Best Answer10-25-2022 20:28
10-25-2022 20:28
11:14
03:34
10-27-2022
11:14
03:34
@shahzam04 Thank you for sharing this update.
I'm sorry to see the troubleshooting steps were not successful, but it's good to know that you'll be receiving a replacement soon!
See you around in the Community. 😁
Best Answer10-29-2022 18:22
10-29-2022 18:22
03:25
10:32
DavideFitbit
10-30-2022
03:25
10:32
DavideFitbit
I have the same problem, I have been through all of the troubleshooting steps, I did the 3 presses in 8 seconds.
I get the Fitbit logo for maybe 1 second - apart from that it is completely unresponsive
I ordered my Charge 5 on 24 October 22, and it has had the above problems out of the box.
this is not good enough for a $270 watch.
I am about to buy an Apple Watch because clearly Fitbit are a waste of money and buying Fitbit is basically throwing away $300 each time.
Moderator edit: format
10:32
03:34
11-19-2022
10:32
03:34
@MXC29 Thanks for all the information and updates provided. It's good to know that you've received a replacement and that it's been working properly.
@Yo12 I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've shared some instructions with you. In this case, they will let you know how to proceed and I recommend that you continue the communication with them.
Best Answer05-10-2023 11:27
05-10-2023 11:27
I have the same issue and was able to get the Charge 5 to recover a couple times after fully draining power and re-connecting via the App, but just keeps going back into stuck logo mode. My Charge 5 is just over a year old and so outside the 1 year warranty which is unfortunate as this appears to be a common problem without a fix. For now, I am left reverting to my Charge 2 which is still working without issue after 8 years and does not make sense to buy another Charge 5 if they don't last very long.
05-10-2023 13:24
05-10-2023 13:24
My charge 5 never recovered - even after troubleshooting steps carried out,
I now have an Apple Watch - no trouble at all for the past 6 months
