05-15-2022
13:15
07:32
DavideFitbit
05-15-2022
13:15
07:32
DavideFitbit
The white x appeared. I cannot shut down or reset the Fitbit.
Moderator edit: format
07:31
13:13
05-17-2022
07:31
13:13
Hi, welcome to the Fitbit Community forums, @KB-Blessed.
Thank you for all the details provided about this inconvenience with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, you can also try setting up your Charge 5 as a new device in the account or changing the clock face option, as this has been useful for other users with similar problems.
Hope this helps, I'll be around.
07:52
10:20
DavideFitbit
05-17-2022
07:52
10:20
DavideFitbit
Great - thank you for responding. The fitbit is working now.
Thanks and Blessings,
