07-22-2022 08:35
07-22-2022 08:35
Hey there,
I recently changed the pool length on my Charge 5 as I was swimming at my local outdoor pool which is much larger than the indoor.
When I looked at the results afterwards on my phone, it was acknowledging the new 90m pool length…. However it was still calculating it as 25m. So…
I swam 8 lengths at 90m. So 720m swim.
However my app said I did 29 lengths and therefore calculated a 2639m swim!!! Which in just over 30 mins puts me in the Elite territory - trust me, I’m not. 😀
If you do 29 (lengths) x 25 (meters - the old pool distance) you get the correct distance. However the app and the charge 5 are both saying that the pool distance is 90. So there seems to be some kind of internal calculation still fixed on 25m.
Any ideas gratefully received.
Thank you!
Best Answer07-22-2022 09:56
07-22-2022 09:56
I should add that as a result of this glitch it returns very elevated calorie and zone minute calculations for my workout.
Considering I’m trying to lose weight and keeping an eye on calories I burn etc… this is quite frustrating.
It’s also bizarre that zone minutes are being calculated considering I thought the HR monitor is turned off for swims? Is this a glitch too or does Fitbit make a guesstimate based on the distance/ time I swim. Either way…. Still elevated and inaccurate.
Best Answer07-25-2022 02:25
07-25-2022 02:25
Following this up with this morning’s swim. Still causing problems. Charge 5 also saying 91m. I did 8 lengths not 23 so this throws everything wildly out of whack and makes me look like I should be in training for the Olympics!
Can anyone from the @Fitbit Moderator team shed any light please.
