07-19-2022 00:34
07-19-2022 00:34
I tried updating my Charge 5 today (19 July 2022). It got stuck in the process at 80%, device is unresponsive and manual restart (via the cable) doesn't work. Do you have any advice how to solve this issue?
Best Answer07-19-2022 01:24 - edited 07-19-2022 01:31
Hi, maybe a hard reset would work. It's a bit extreme, so maybe someone has a better idea.
For this, plug your Charge like when you charge it, and press the cable button 3 times, waiting 1 second each time.
Wait for 10 seconds and see if it restarts.
You will loose the data stored in your Charge, though.
EDIT : sorry, I got all mixed up. I think that's exactly what you have tried to do... And you're right, it's a restart, not a reset.
Sorry for the confusion.
07-19-2022 01:43 - edited 07-19-2022 01:44
Yeah, already tried that (multiply times), no success. It restarts and I'm back to where I was (update progress at around 80%).
Also, I can't update the firmware again in the app, the button is greyed out (not active, not clickable). Any advice in that?
07-19-2022 01:50
07-19-2022 01:50
So even the 3 pulse restart cant save it? You probably should contact customer support right away.
07-19-2022 02:44
07-19-2022 02:44
Thanks, I did contact the support. They were fast. Apparently this can't be fixed (!). I'm eligible for a replacement.
07-19-2022 02:59
07-19-2022 02:59
Ok, thanks for letting us know.
They're generally very fast in sending the replacement too.
Best Answer07-19-2022 04:11
07-19-2022 04:11
Same thing as just happened to however i did get the full install and a completed message, the screen is now not responding.
Best Answer07-19-2022 04:29
07-19-2022 04:29
Have you tried restarting it ?
If not, plug your Charge like when you charge it, and press the cable button 3 times, waiting 1 second each time.
Is the screen completely black ? Are the green lights on the back blinking or completely off ?
Best Answer07-19-2022 04:38
07-19-2022 04:38
My screen is black even after restart but I do see the light on back blinking green.
What the next step?
Best Answer07-19-2022 04:51
07-19-2022 04:51
Hi,
Ok, so the ideal next step would have been to reset your Charge but for that, you must be able to use the Charge's screen and scroll up and down...
There is no other way to reset it that I know of.
So the next step is to contact customer support. Give them as much details as you can right away in your first message to speed up the process.
They're generally very fast in getting you sorted.
Good luck, and keep us informed if you can, this could help other people.
Best Answer07-19-2022 04:53
07-19-2022 04:53
Have you tried the 3 pulse restart? Thats the last resort normally.
07-19-2022 04:53 - edited 07-19-2022 05:01
You can use the charging cable to restart which is a better way, in case even the device screen is not responding.
Best Answer07-19-2022 23:06
07-19-2022 23:06
Do anyone still experience problems during the new update? If so, shall we hold until this is resolved.
Best Answer07-20-2022 01:18
07-20-2022 01:18
After the update it looks like for some reason it drained my battery which was at 25% charge before and 19% after the update, once i got home and reconnected to the charger it started again.
I have been keeping an eye on the battery discharge and it all seems back to normal .
