05-25-2022
07:12
07:10
DavideFitbit
05-25-2022
07:12
07:10
DavideFitbit
My Charge 5 vibrates only twice for calls
05-26-2022
07:08
10:07
05-26-2022
07:08
10:07
Hi, welcome to the Community forums, @Carterdave.
Thank you for the information provided about your Charge 5.
Before considering other options, could you please provide a few extra details? Let me know if you notice any difference in the vibration between the notifications from calls, text messages or third party apps. In the meantime, you can try restarting the device to confirm if you see any changes.
I'll be around.
05-26-2022
07:36
11:29
DavideFitbit
05-26-2022
07:36
11:29
DavideFitbit
It only vibrates twice for calls then stops , but the alarm works well
I have tried restarting and even clearing user data
It still doesn't work
The vibration motor sounds so bad
06-03-2022
11:26
06:58
06-03-2022
11:26
06:58
@Carterdave Thank you for sharing all these details.
I was able to check the two vibrations (for calls) are an intended functionality of Fitbit devices and at the time, there is no way to personalize that specific behavior.
The reason is because if it vibrates more than twice, this causes the battery to drain quicker. However, I do recommend that you vote for this idea posted in the Feature Suggestion board of the Community: Customizable vibration length and patterns for notifications. This is always helpful for the team of developers to continue to track popularity and demand over time.
However, if you feel the vibration motor is not sounding or working properly and you already tried the steps suggested earlier, I recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected
See you around.
10-29-2022 08:40
10-29-2022 08:40
Can't agree with the only vibrate twice answer to save battery .My cheap £20 smart watch i had before the ch 5 used to keep vibrating till I answered the call .And I only had to charge it about every 4 days.
11-17-2022
09:50
16:11
11-17-2022
09:50
16:11
Welcome to the Community forums, @Kanazawa.
Thanks for taking the time to share your feedback and comments about the battery life and your experience with your other device. The team continues to work to improve the Fitbit experience and your feedback is big part of that process.
Have a good day.
