07-05-2023
19:32
08:02
DavideFitbit
07-05-2023
19:32
08:02
DavideFitbit
Hi, just wanted to let everyone know that your Charge 5 is only waterproof for the warranty period. After that it will probably die like mine did and you are just offered a discount on a new one.
Moderator edit: format
07-09-2023 08:01
07-09-2023 08:01
Hi everyone, thank you for all the information and feedback provided about swimming with your Charge 5.
As some of you mentioned earlier, you should be able to swim with your Charge 5 device, since it's water resistant to 50 meters. You can find more information about this here. If you experienced any problem with the device not responding after swimming, please make sure to get in touch with the Customer Support team here or continue the communication with them if you already have a case created with them.
It is particularly difficult when the device is no longer covered by the warranty, but even tough Support is eager to help with any problem you may experience with the product, they do need to adhere to the official warranty policy, this would start counting from the original date of purchase.
Thank you for taking the time to share your feedback regarding the quality; comments from users are always useful to continue improving the quality of products and services.
07-05-2023 19:52
07-05-2023 19:52
Hi @Fchingy the Charge 5 is water resistant, not waterproof. See page 55 of the user manual.
07-06-2023 12:36
07-06-2023 12:36
Just learned this the hard way too... Forgot to take off my Fitbit Charger 5 before jumping into the pool and the device just died.... I bought in Feb 2022 and, obviously, it's out of warranty now. Got a 35% discount code to buy a new one..
07-07-2023 11:44
07-07-2023 11:44
The manual also gives instructions on swimming with it and showering with it. Presumably, it's meant to handle getting wet without suffering permanent damage, right? Or am I misinterpreting something?
07-08-2023 16:54
07-08-2023 16:54
It also has a setting to track your swim, so I assume that means you can swim with it. If it can't handle that, they shouldn't have a setting for swimming..
07-09-2023 07:38
07-09-2023 07:38
Hi, Mine Charge 4 was broken in the warranty period and replaced by a Charge 5 (Charge 4 was taken out of the collection because of this construction failure).
The Charge 5 I recieved in october last year, was working fine until I forgot to take it of when swimming in a pool (perhaps 1,5 mtr deep). Now it is completly dead. They gave only the warrant time of the Charge 4.
Fitbit clearly has no confidence in their own products.
07-09-2023 08:01
07-09-2023 08:01
