11-15-2022
07:38
07:04
DavideFitbit
11-15-2022
07:38
07:04
DavideFitbit
Continues to show Yesterdays information Will not reset
Welcome to the Fitbit Community forums, @BBjones32.
Thanks for sharing that you've been having this issue with your Charge 5.
I've seen other users experiencing something similar in the past. Before considering other options, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
If the issue persists, you can also try setting up your Charge 5 as a new device in your account.
Hope this helps, I'll be around.
