08-28-2023
06:42
07:23
08-28-2023
06:42
07:23
my charge 5 will not hold a charge. i have charged it overnight 2 days in a row because it has totally run down during the day. this does not help when you are trying to monitor your sleep hours.
Best Answer08-28-2023 07:43
08-28-2023 07:43
Hello, just wanted to give you a real answer instead of the Fitbit corporate jargon they have to tell you as a support team.
In July they released a firmware update that has effectively rendered the Charge 5 useless. You'll be lucky to get eight hours out of it now. Ironic, seeing as the device's name is Charge haha. Anyway, Fitbit is basically acting as if it's not a thing and offering people replacements if they're under warranty...which will of course suffer from the same problems since it'll be on the same firmware.
Hope this helps. You just have to keep charging it and wait to for them to patch it, if they even do.
08-28-2023 07:25
08-28-2023 07:25
Hi there, @wonderingwhy. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
Regarding the battery short life, in general, it is recommended to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. This should also help with the problem you mentioned with the display:
08-28-2023 07:43
08-28-2023 10:43
08-28-2023 10:43
Hello @wonderingwhy
When my Charge 5 started to rapidly lose power, I restarted & recharged my device multiple times over several days. This eventually got my device "unstuck" and the battery went back to lasting 6-7 days.
One of our users wrote a post with detailed steps that they used which seemed to help reduce battery drain. Click here for: Possible fix for rapid battery drain
Hopefully, these troubleshooting tips will be successful for you.
