09-27-2023
22:38
04:05
09-27-2023
22:38
04:05
Since the beginning of August, my charge 5 has not held its charge. The battery will be at 100% and I'll unplug it and it'll be dead and run out of charge again within a few hours. I have tried restarting it and there are no firmware updates as have been suggested to other people but I am still having this problem. My watch isn't even a year old. Is there anything else I can do it does it need to go back to fitbit?
Hi there, @Stilldreamin. Thanks for stopping by in the Fitbit Community Forums. I appreciate you've taken the time to troubleshoot the issue with your Charge 5 before reaching out.
Regarding the battery short life, in general, it is recommended to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm you performed the restart as described below:
Hello @MarreFitbit ,
Thank you for your response. I tried the 3 tap restart and that hadn't worked either. My fitbit is still draining from 100% to empty within 2-3 hours.
Hello @Stilldreamin
When my Charge 5 battery started losing power rapidly, I restarted and recharged my device multiple times over several days. Eventually, this process got my Charge 5 "unstuck" and the battery went back to lasting 6-7 days.
If you try this and are not successful, you probably should contact Fitbit support (<-- click link), especially since your device is less than a year old.
Thanks, I've tried several times over the last few weeks and it's still doing it. Thanks for the tip, I'll get in touch with them.
