05-23-2024
21:37
04:40
05-23-2024
21:37
04:40
I bought a fitbit charge 5 about 1 year ago and its been working fine since. However recently it hasn't been holding its charge and running out of battery in less then a day. I haven't changed any settings that would effect battery life. I've restarted it and factory reset it but still no luck.
05-23-2024 23:55
05-23-2024 23:55
Im the same, past 2 days. Have tried reset. Not helped
05-24-2024 03:21
05-24-2024 03:21
Mine started doing this one week ago. first I noticed it was dead it didn't last a day, the unit would not charge and the firmware was jammed making it unable to start I resolved these issues with a bunch or resets and patience. After that I noticed the battery seems to die about 20 hours after a full charge,
It's not an old unit but something changed on this and it's no longer usable.
05-24-2024 04:14
05-24-2024 04:14
Just come here to see if anyone else is having that problem. I’m charging mine twice a day. It’s driving me crazy. I’ve tried all kinds but it’s not fixing it 😢
05-24-2024 06:01
05-24-2024 06:01
Same - today and yesterday, my Charge 5 goes from fully charged in the morning and is dead by the time I track my bike ride into work (about 40 minutes). Was fine last week.
05-24-2024 07:05
05-24-2024 07:05
Mine’s exactly the same - won’t hold the charge at all now. Charged to 100% at 10am and down to 79% by 1pm and I haven’t even left my desk!! And it’s only 2-yrs old.
A few months ago it held a charge for 7-10 days. I never use GPS, notifications, link to my phone as these were battery drainers when I first bought it!!
And now the App on the iPhone is unreliable recording pace when I walk or run. Whole product is virtually unusable and I used to love my Fitbit. Will not buy another now unless Fitbit can convince me otherwise ???
05-25-2024 13:37 - edited 05-25-2024 14:49
When my Charge 5 started having rapid battery drain, I restarted and recharged my device multiple times over several days. As soon as I noticed the battery% had a big drop, I restarted and put my Fitbit on the charger, often doing this multiple times in a day. This process eventually got my Charge 5 "unstuck" and the battery life went back to lasting 6-7 days. Although there's no guarantee that this will work, it might be worth a try.
05-25-2024 14:00
05-25-2024 14:00
Same here. I have tried the USB charger reset and the device restart. Battery drains quickly and device no longer records any data - steps, distance, activity. I have cleared the user data (based on advice for not counting steps) and now the device simply cycles looking for something. I can no longer sync. The device does not go into a mode where it can be paired to Bluetooth.
06-06-2024 05:33
06-06-2024 05:33
Same thing happened to me about a week ago. Went from 7-10 days to not making it a full day without needing a charge. Extremely frustrating.
Best Answer06-06-2024 10:03
06-06-2024 10:03
Mines been the same for the last week. It won't hold charge for the usual 5-7 days it would do. Now it wont last 18 hours without battery drainage. I had only bought it in May last year. I have currently gone back to one that isn't Fitbit and it still works as good as the day I decided to leave that one and return to the Fitbit world as I ordered the charge 5. I can honestly say that I will not be returning for a third time unless fitbit resolve this issue very soon. Fitbit charge 5 charged this morning at the same time as my Huawei Band 4 Pro, fitbit battery life after sitting in my bag all day is currently 53%. Huawei Band 4 Pro battery life after being on my wrist all day and in use is currently 93%. Clearly a winner here and its not Fitbit
06-06-2024 10:18
06-06-2024 10:18
