11-03-2025
23:59
03:54
11-03-2025
23:59
03:54
In the last few days I have found my fitbit charger 5 is rapid losing it's battery life. Charging it till 100% 3 times a day. Why should this suddenly happen?
Hi there, @CB_Magdalen. It's nice to see you around the Fitbit Community Forums. I'm sorry to hear that your Charge 5 is not holding a charge. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend making sure that your phone's software version is updated. For more information, refer to Check & update your Android version or Update your iPhone or iPad
If you haven't done so yet, please try all tips and recommendations provided here Can I extend my Fitbit device's battery life?
Sorry, I have tried the suggested checks and updates. Nothing seems to need changing but my Fitbit battery charge is just depleting.
Also, my Fitbit has a solid, constant green light on the back of the pebble this is very different to previously were I had a dim pulsing green light.
@CB_Magdalen Thanks for getting back to me and for trying the steps I recommended.
To better assist you, I suggest reaching out to our Support Team who will be able to take a closer look into this issue and provide further help. This form is only meant for you to use. Click here to get access to it.
