09-07-2022
15:03
10:20
DavideFitbit
09-07-2022
15:03
10:20
DavideFitbit
Had my Charge 5 for 9 months and it’s suddenly stopped holding charge. I have to charge it the moment I wake up and then the moment I get back from work/ before I want to go to bed so I can track sleep.
Moderator edit: format
09-09-2022
10:19
04:18
09-09-2022
10:19
04:18
Welcome to the Fitbit Community forums, @Anononon.
Thank you for the information provided about the inconvenience with the battery of your Charge 5.
If you haven't done so already, please make sure that you've followed the steps provided in this article. In addition, try completing a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery of the Charge 5 can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
Let me know if you continue to experience the same problem afterwards.
I'll be around.
