09-22-2023
19:48
04:40
09-22-2023
19:48
04:40
We have done the reset several times to no avail. Cleaned contacts. The Fitbit app no longer finds the device to sync. What is the next step?
Best Answer09-23-2023 04:43
09-23-2023 04:43
Hi there, @Jlrrob. Welcome to the Fitbit Community Forums. Thanks for taking the time to troubleshoot the issue with your Charge 5 before reaching out.
As per the description of your post, it seems like your Charge 5 is having battery issues. If you've tried charging your Charge 5 for more than 2 hours but to no avail, please make sure you've followed all tips and recommendations provided here Why ins't my FItbit device's battery charging?
If the above doesn't work, connect your Charge 5 to the charger and try the following (while it's connected to the charging cable and even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
09-23-2023 04:43
