09-30-2023
17:54
07:48
09-30-2023
17:54
07:48
Charge 5 and app are not syncing
Hi there, @Beejhs @CarlJac @HerbalT. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
As a first approach, I'd recommend following the troubleshooting steps provided here Why won't my Fitbit device sync?
If the above doesn't work, please try these steps in the order listed:
I am having difficulties also since the new interface. I go into settings and can do it from there but thats a pain
I finally contacted tech support and they had a similar answer that you gave and it’s working properly now.
Reset Fitbit then reinstall it as if a new device!! Then turn phone off and on again.
Hi there, @Beejhs. Thanks for stopping by in the Fitbit Community Forums. I'm glad to hear that your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Have a nice day!
